Viking-Pilot
Jan 10, 2023Aspirant
R6400 AC1750 Connect USB Hard drive
I am trying to connect a My Book 6TB hard drive to the 3.0 USB port. Model number; WDBBB0060HBK-NESN The hard drive is not showing up in the Ready Share panel. Is this a non supported hard drive or...
Viking-Pilot
I pugged in a very old WD My Book and it came up no problem!
So what does that tell me?
michaelkenward
Jan 10, 2023Guru - Experienced User
That maybe your drive is not compatible.
After all, your 2015 vintage R6400 is a bit long in the tooth.
- Viking-PilotJan 10, 2023Aspirant
That is a concern I had. I can't find any information on compatibility.
