JonGe
Nov 21, 2021Aspirant
r6400 ac1750 intermittent internet
This unit is less than a year old. Since the last firmware update (v1.0.1.76_1.08.48) has had slow internet and web pages that I have to keep reloading because it is unable to connect. This problem...
wcalifas
Nov 24, 2021Prodigy
You can try reverting back to a previous firmware and see if that helps but you will have to manually install the firmware. Make sure you click off automatic updates if you reset your router because it will update it to the firmware that's giving you issues.
JonGe
Jan 18, 2022Aspirant
thanks for the reply.
How do I find previous firmware for my model?
- wcalifasJan 18, 2022ProdigyGo to www.netgear.com and click on support then on the box that appears write the model r6400 and then click on downloads and on the + sign you'll be able to see the previous firmwares to download
