TechLady
Jul 24, 2016Aspirant
R6400 AC1750 Smart WiFi Router -- Router update failed
Current version V1.0.1.6_1.0.4 New version V1.0.1.12_1.0.11 (Windows 8) Several failures. Initiated update from Genie. Then followed instructions to log into router, go to Advanced/A...
- Jul 25, 2016
Hi TechLady,
You can try to manually update the router's firmware then reset and reconfigure the settings. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23289
http://kb.netgear.com/app/answers/detail/a_id/24830Regards,
Dexter
Community Team
SueQKY
Aug 10, 2016Guide
Hi-
1.To be accurate, the update was actually downloaded and working well, several weeks back when I first saw the notification. No, I didn't do a factory reset, only entered any configuration info it was missing as I progressed back into normal usage. Friday morning I had a pop-up window on my mobile asking for my router channel password. I didn't enter it, because all had been working well up to that moment, and instead, after several attempts at just reconnecting, rebooted the mobile. At that point, the router reconnected the mobile to the ISP connection as per normal, without a re-enter of a password. It was after that when I found I had No Service for the cell - due to no signal to the microcell. Hmmmmm-
2. Am not savvy enough just yet to know whether the device is set to port forwarding or not. I'm sure I'll learn all about it now that you've mentioned that possibility!
Thanks.
DexterJB
Aug 11, 2016NETGEAR Moderator
Hi SueQKY,
We highly recommend doing a factory reset after a firmware update then reconfiguring the router. The Microcell should reconnect without a problem not unless there are additional settings required by your ISP.
Dexter
Community Team
- SueQKYAug 13, 2016Guide
TY- the microcell connection interruption recurred yet again. I thought I had taken care of the password compromise issue involving the R6400 back when informed about it, but apparently had not. I reinstalled the firmware update, reset the router, then re-entered all the necessary configuration info as needed, including new passwords. All seems to be working well at this point. Not sure if this question is addressed in a different thread, which I'll check on - how often do you routinely change the password on your router/channels?
Thanks!
- DexterJBAug 14, 2016NETGEAR Moderator
Hi SueQKY,
Good to know everything is working fine.
If you are referring to the WiFi password, there is no specific time on how often you should change it for as long as you make sure that it is only you or the people/devices you have authorized to connect to your network that have the information.
Dexter
Community Team
- SueQKYAug 16, 2016Guide
Well, not only the wifi channel passwords, but the router password, as well. Do you make changing that password part of your regular maintenance tasks? And, sorry to say, the microcell isn't working once again. Have asked for an exchange, perhaps something wrong with the device. All the indicator lights are lit except receiving signal from the router/modem, it just blinks. AT&T continues to remind me that microcells do not work well with satellite service, but I purchased it at their suggestion to improve my cell service. So by golly, since I had to pay for it, it WILL work :(
Oh, and about the port forwarding? Would you point me to any links that would instruct me as to how to do that, if still recommended? I've searched the community posts, but they're a bit over my head in tech info. Don't have a clue which ports to use alternately, how to go about it, etc.
Thanks-
