TechLady
Jul 24, 2016Aspirant
R6400 AC1750 Smart WiFi Router -- Router update failed
Current version V1.0.1.6_1.0.4 New version V1.0.1.12_1.0.11 (Windows 8) Several failures. Initiated update from Genie. Then followed instructions to log into router, go to Advanced/A...
- Jul 25, 2016
Hi TechLady,
You can try to manually update the router's firmware then reset and reconfigure the settings. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23289
http://kb.netgear.com/app/answers/detail/a_id/24830Regards,
Dexter
Community Team
DexterJB
Aug 14, 2016NETGEAR Moderator
Hi SueQKY,
Good to know everything is working fine.
If you are referring to the WiFi password, there is no specific time on how often you should change it for as long as you make sure that it is only you or the people/devices you have authorized to connect to your network that have the information.
Dexter
Community Team
SueQKY
Aug 16, 2016Guide
Well, not only the wifi channel passwords, but the router password, as well. Do you make changing that password part of your regular maintenance tasks? And, sorry to say, the microcell isn't working once again. Have asked for an exchange, perhaps something wrong with the device. All the indicator lights are lit except receiving signal from the router/modem, it just blinks. AT&T continues to remind me that microcells do not work well with satellite service, but I purchased it at their suggestion to improve my cell service. So by golly, since I had to pay for it, it WILL work :(
Oh, and about the port forwarding? Would you point me to any links that would instruct me as to how to do that, if still recommended? I've searched the community posts, but they're a bit over my head in tech info. Don't have a clue which ports to use alternately, how to go about it, etc.
Thanks-
- DexterJBAug 17, 2016NETGEAR Moderator
Hi SueQKY,
What is highly recommended is changing the router password from the default one and have it different from your WiFi password.
Port forwarding will require specific information from the AT&T such as the port numbers and protocols. If you already have that information, you may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24046
Dexter
Community Team
