Elklakenetguy's avatar
Sep 01, 2022
R6400 add on another AP
Hello, I am using my Netgear R6400 configured as an Access Point in a second building, connected to main router in main building via Ethernet using cable wiring and MOCA adapters.  It is working fine in the second building.  I would like to add another AP outdoors near the R6400 location.  Can I use an Ethernet connection from the R6400 AP to yet another AP unit located nearby outdoors?  Signal strength from R6400 outside is poor due to metal in walls of the building where it is located.
Thanks for any help and insights.
    Should work. But you don't have to use another router. Any extender in AP mode should also work.
    "Daisychaining" devices might not be as fast as you'd like, but it would be better than using a repeater. The R6400 does support "bridge" mode like that, but that it likely to be even slower.
  • michaelkenward's avatar
    michaelkenward
    • Elklakenetguy's avatar
      Elklakenetguy
      Just a follow up, this indeed did work just fine.  The Netgear router had a setting for AP, using the WAN connection, works great as an AP, I found that to get everything I wanted to work properly, I assigned the AP and the devices connected to it manual (fixed) IP addresses, which kept various wifi connected things from losing their connection.
