bemused59
Jun 30, 2016Aspirant
R6400 after firmware update, Genie tells me WiFi Connectivity Not Enabled... but I have wifi...?
In the course of troubleshooting connectivity issues after a power outage, I updated the firmware via NETGEAR Genie. Have all connectivity back, but on the "Home" page of the Genie, I have a STATUS: ...
- Jul 03, 2016
Hi bemused59,
The message on the "Home" page of the NETGEAR Genie indicates that either the device you are currently using does not have a wireless adapter or you have it disable/turned off. If you are using a laptop, it is possible that it has a physical wireless switch that needs to be toggled on or off. I recommend checking the user manual for that.
Dexter
Community Team
DexterJB
Jul 03, 2016NETGEAR Moderator
Hi bemused59,
Dexter
Community Team
- bemused59Jul 03, 2016Aspirant
Thanks, Dexter... the Genie is loaded on my PC, which does NOT have wireless capability -- so that explains it perfectly.
Appreciate you clearing that up for me, I will immediately stop worrying about it. {~;
