ardvaaark
Feb 28, 2017Aspirant
R6400 and DM200 setup
Hi, I have just bought a DM200 model and an R6400 router. It is not dlear at all how to set together and I have not managed to get internet into the R6400 Does the ADSL setting happen on ...
- Mar 06, 2017
Hi All,
Thank you for your assistance.You were all helpful. The theme was set the modem into bridge (Modem) mode and configure the settings in the router with ISP username passowrd etc...
This would have been correct but I have not accepted any solution becuase of one thing that blocked it and the whole community needs to know. AC1750 does not have PPPoA. Even with latest firmware update. Confirmed by Netgear. What ????? Anyway no matter all your posts my ISP must have PPPoA so it never did work.
It is possible to leave the modem in modem+router mode, log in on the modem, say to the AC1750 that my ISP does not require a login, and then the modem will pass data to the AC1750. The problem here is you have double NAT double DHCP etc...
Fine, turn off the DHCP on one of them for example.... I tried that a lot but there were a lot of error mesages saying the IP on the router has been reset to 192.168.1.1 to avoid a clash with the ISP. In this case the ISP 'it' saw was the modem. The modem was passing a private IP to the router and that was stuck on 192.168.1.1, my whole network with many fixed IP's is on 192.168.2.x so I didn't really want to fiddle with that.So long story short is that it didn't work terribly well at all. the root cause of all of the pain was no PPPoA in the AC1750 (R6400) - really poor netgear, considering it's quite highly priced.
Thanks all.
ardvaaark
Mar 06, 2017Aspirant
Hi All,
Thanks all.
aalexandrebeta
Mar 06, 2017Master
I configured my DM200 with Modem+router mode with the 192.xxx.5.1
Then the R8500 is 192.168.1.1 with no issues even with double DHCP and NAT.
You can try?
If you have still enough juice left keep me in the loop.
- ardvaaarkMar 06, 2017Aspirant
Cheers yes I could do that but I have a lot of devices on the netowrk and many fxid IP's and all 192.168.2.x
I don't want to do to the trouble of changing them all to 192.168.1.x - ardvaaarkMar 06, 2017Aspirant
Plus then if I do NAT, Upnp, Modem, DHCP all in the modem - why am I buying an AC1750 for £100 - it's just being used as a wireless access point in that configuration.
