KJ1231
Jan 16, 2017Tutor
R6400 as second router
I have a Verizon FiOS router and the R6400. I have run Ethernet upstairs and want to connect R6400 to FiOS and use as wireless AP but want to see wired devices on the FiOS router. The wired devices...
- Jan 16, 2017
If by "see" you mean communicate with them, then yes.
If you use the AP mode setting, then FiOS LAN goes to R6400 WAN. The onscreen instructions are pretty clear.
TheEther
Jan 16, 2017Guru
Log into the R6400, go to ADVANCED > Advanced Setup > Wireless AP and enable AP Mode. This is the easiest way to set it up.
You can also use the old school method of disabling the DHCP server but it requires a little more fidding with IP addressing. If you have Gigabit Internet service, this will be faster, too.
KJ1231
Jan 16, 2017Tutor
THANKS! Will this allow me to see the devices connected to the FiOS router, the wired ones in particular?
And ethernet from from FiOS LAN port goes to R6400 LAN or WAN?
Thanks again!
- TheEtherJan 16, 2017Guru
- KJ1231Jan 17, 2017Tutor
Not sure what I did the first time I set it up as an AP but it is working now and I can see all the attached devices. Thanks for taking the time to respond!
