cfslmunchies
Oct 02, 2018Aspirant
R6400 cannot update firmware
Received an email that said there is a new firmware. I have done this in the past and it has always worked. I see the firmware upgrade is a new number, 1.0.1.44. I have 1.0.1.42. However, when I...
- Oct 02, 2018
> [...] it says that the page will not load because I do not have
> javascript allowed. But I do.
You don't need to persuade me, you need to persuade your router
and/or web browser. The router web site, no doubt, uses JavaScript.
> Have you tried a different computer or browser (or disabling some
> over-eager anti-virus program, ...)?
Still wondering.
> My bigger concern is why does nighthawk and netgear genie say that
> there are no updates for my router when there is one?
A frequent question these days, as a casual look at these forums will
show.
cfslmunchies
I was following the instructions below.
R6400-V1.0.1.44_1.0.31.chk is on my desktop.
However, when I enter http://www.routerlogin.net into chrome or ie, it says that the page will not load because I do not have javascript allowed. But I do.
My bigger concern is why does nighthawk and netgear genie say that there are no updates for my router when there is one?
To update the router’s firmware:
- Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
- Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is R6400-V1.0.1.44_1.0.31.chk
Download Link:http://www.downloads.netgear.com/files/GDC/R6400/R6400-V1.0.1.44_1.0.31.zip
- To log in to the router, launch a web browser and enter http://www.routerlogin.net.
- Enter the router user name and password.The user name is admin. The default password is password. The user name and password are case-sensitive.The BASIC Home screen displays.
- Select ADVANCED > Administration > Router Upgrade. The Router Update screen displays.
- Click the Browse button and find the file you just downloaded.
- Click the Upload button.
Do not interrupt the update while the router does this step.
antinode
Oct 02, 2018Guru
Still wondering.
show.
- cfslmunchiesOct 03, 2018Aspirant
I did try internet explorer after it did not work on chrome. Same result. I will try disengaging the anti virus software. Thanks for the tips.
I will also try my laptop
Thanks
Okay, it worked when I disabled the anti virus software. Thanks for your help. In the past, the updates worked without doing anything extra. I am not a computer expert as I am sure you can tell. But again, thanks antinode.
