akishore
May 16, 2016Tutor
R6400 Causing Slow Data Transfer over LAN
Hi all, So I'm having some speed issues that I was hoping someone could help me with. This is not an issue with Internet speed, but LAN speed. Let me explain my configuration first. I just bo...
- May 16, 2016
You are probably running into the fact that AP Mode disables the hardware accelerated traffic processing between the Internet and LAN ports. This forces the CPU to handle packets. Unfortunately, the CPU can't forward at Gigabit rates.
Fortunately, there's a workaround, which is to set up the router as an Access Point using the old school method. Start off by disabling AP Mode. Make sure the Internet port is not configured with any static IP address. Go to LAN Setup and configure an IP address in the same subnet as your main router, but make sure to use an address outside of the DHCP range managed by the main router. Otherwise, you run the risk of an IP address conflict. Adjust the DHCP range on the main router to free up 3 IP addresses, if necessary. Manually disable the DHCP Server. Save the changes. Finally, connect the R6400 to your Ethernet backbone via a LAN port. Leave the Internet port disconnected. You won't be using it. You'll only be using the built-in Ethernet and WLAN ports as a switch. You should be able to achieve near Gigabit rates with this setup.
TheEther
May 16, 2016Guru
- akishoreMay 16, 2016Tutor
Wow, that was right on the money! Thanks for the excellent info, but I did find a slightly faster solution. Instead of disabling AP mode and manually adjusting all the settings, I just conneted the everything to the LAN ports and left Internet port empty. That increased the speed back up to 110 Mbps.
I also checked that I can still access the Internet using that router by manually connecting to that one and the Internet worked also. Would you see any advantage to disabling Access Point mode if this is working?
Also, why does it disable hardware accelerated traffic just becuase you're using it as an Access Point? What's the logic? Does every brand do this or just Netgear?
Thanks for your help!
- TheEtherMay 16, 2016Guru
Yeah, that should work, too. Do you have it set up to obtain an address dynamically? If so, I'm not sure it will acquire one if the Internet port is unused. You may be unable to log in. You can try switching it to a static IP address.
I'm not deeply familiar with Netgear's router architecture. All I know is that ene of the ports on the Broadcom switch can be designated as a WAN port, in which case all traffic is forwarded through the CPU. Evidentally, Netgear chose to do this with AP Mode.
I went in and changed the IP addresses on each R6400 to a static IP address. I first logged into the FIOS router and blocked out 192.168.1.1 to .10 from DHCP, so that it doesn't try to assign those to any device.
All is working well now, just wish they didn't forward the traffic in AP mode, but oh well.
Thanks again for the help.
