PixelZealot
Jun 16, 2016Aspirant
R6400 Change DHCP Lease Time
Can you not change the default lease time on these? I can't find the setting anywhere. Every router I've ever owned I've been able to do this. This is a great router otherwise, but I'd really like...
- Jun 24, 2016
Yeah, I know it should be smooth...but sometimes that doesn't happen...and it's probably a Windows issue from what I have learned, as it will happen on some computers and not others...either way, long lease time prevents people occassionly losing their connection every day and I don't have to listen to their whining =). It's worked for me over the years...I prefer a longer least time, that's all.
It's really pointless talking about this with this router anyway, as it can't be changed. Thanks, though.
Anonymous
Jun 16, 2016First Netgear router?
You cannot change the lease time.
