mccabc13's avatar
mccabc13
R6400 crashed during firmware update bricked itself
Is there any way to fix this? the power light is white and flashing. I cant reinstall the firmware because its not connecting to my pc on a wired connection. it just has a red light on whatever ethernet port i plug it into. so i cant assign a ststic ip address and reinstall firmware. Please help
  • > Model: R6400|AC1750 Smart WiFi Router
       Is that accurate?  R6400 or R6400v2?  Look for "Model" on the product
    label.  Firmware version (if known)?  Connected to what?
    > [...] the power light is white and flashing. [...]
       You may be a candidate for the TFTP recovery scheme.  See, for
    example:
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
    > [...] I cant reinstall the firmware because its not connecting to my
    > pc on a wired connection. [...]
       "can[']t" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.  "because" is open to dispute.  What's
    your evidence?
    > [...] it just has a red light on whatever ethernet port i plug it
    > into. [...]
       "red" or "amber"?  An amber port-status LED is hardly fatal.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for the
    LED descriptions and "Troubleshoot".  Further reading might not hurt,
    either.
    > [...] so [...]
       See "because", above.
    > [...] i cant assign a ststic ip address and reinstall firmware.
       How, exactly, does any LED color stop you from configuring the IP
    parameters on the Ethernet interface on your (unspecified) computer in
    any way you might wish?
       Note: "cant" is a word, different from "can't".
    • wcalifas's avatar
      wcalifas
      Prodigy
      You need to install the firmware manually with tftp method since it bricked itself. Look up on youtube, how to debrick a router and you also need to download the firmware you want to install on it with tftp.
      • wcalifas is spot on about looking in Youtube.
        There is more severe, recovery reset, that you could try first:
        • Press reset for 30 seconds
        • Keep pressing reset while removing power
        • Keep pressing reset for another 30 seconds while apply power
        If it works, you may be able to use the usual method to flash the firmware again.
        Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
        If that fails, you are into TFTP country.
        How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
        This also explains how to tell Windows to use TFTP on your PC.
        The good news is that TFTP has rescued many a dead device.
