rickyl
Feb 10, 2018Tutor
R6400 crashing overnight with high SY and high WA
My R6400 (F/W V1.0.1.36_1.0.25) has crashed overnight two nights in a row. After the first crash, I started running two telnet sessions from my laptop to the router (via wi-fi) - one running top and ...
- Feb 13, 2018
Thanks for your research and help. I was thinking the same - that it's the internal storage that's failing. It is now occuring at least once a day, randomly. I wonder if there is a way to run something like a chkdsk on the internal storage device? I'd hate to have to trash the router for something that should be fixable.
rickyl
Feb 10, 2018Tutor
Found some more clues, this time in the mtd17 log file:
<3>[598396.820000] SQUASHFS error: Unable to read fragment cache entry [edcf50]
<3>[598396.820000] SQUASHFS error: Unable to read page, block edcf50, size c43c
<0>[598396.820000] Kernel panic - not syncing: Attempted to kill init!
<4>[598396.820000] [<c00552a0>] (unwind_backtrace+0x0/0xe4) from [<c03ac418>] (panic+0x68/0x194)
<4>[598396.830000] [<c03ac418>] (panic+0x68/0x194) from [<c007294c>] (do_exit+0x68/0x608)
<4>[598396.840000] [<c007294c>] (do_exit+0x68/0x608) from [<c00731b0>] (do_group_exit+0x90/0xc0)
<4>[598396.850000] [<c00731b0>] (do_group_exit+0x90/0xc0) from [<c007cfe4>] (get_signal_to_deliver+0x334/0x36c)
<4>[598396.860000] [<c007cfe4>] (get_signal_to_deliver+0x334/0x36c) from [<c0051320>] (do_signal+0x50/0x5d4)
<4>[598396.870000] [<c0051320>] (do_signal+0x50/0x5d4) from [<c0051da0>] (do_notify_resume+0x18/0x38)
<4>[598396.870000] [<c0051da0>] (do_notify_resume+0x18/0x38) from [<c004eaf8>] (work_pending+0x24/0x28)
<2>[598396.880000] CPU0: stopping
<4>[598396.880000] [<c00552a0>] (unwind_backtrace+0x0/0xe4) from [<c004e2f0>] (do_IPI+0xfc/0x180)
<4>[598396.880000] [<c004e2f0>] (do_IPI+0xfc/0x180) from [<c0487ca8>] (__irq_svc+0x48/0xe8)
<4>[598396.880000] Exception stack(0xc04c9f78 to 0xc04c9fc0)
<4>[598396.880000] 9f60: 00000000 d794f000
<4>[598396.880000] 9f80: c04c9fc0 00000000 c04c8000 c04d4bc8 c04f50a8 c04d4bc0 000260e0 413fc090
<4>[598396.880000] 9fa0: 0000001f 00000000 c0548cb8 c04c9fc0 c004fbb0 c004fbb4 60000013 ffffffff
<4>[598396.880000] [<c0487ca8>] (__irq_svc+0x48/0xe8) from [<c004fbb4>] (default_idle+0x24/0x28)
<4>[598396.880000] [<c004fbb4>] (default_idle+0x24/0x28) from [<c004fd1c>] (cpu_idle+0x40/0x94)
<4>[598396.880000] [<c004fd1c>] (cpu_idle+0x40/0x94) from [<c0008c64>] (start_kernel+0x320/0x37c)
<4>[598396.880000] [<c0008c64>] (start_kernel+0x320/0x37c) from [<00008084>] (0x8084)
<4>[598396.880000] NVRAM LOG 16384 23487240 23503624
FS error: squashfs_read_data failed to read block 0xa96a94
<3>[598396.570000] SQUASHFS error: Unable to read data cache entry [a96a94]
including
<3>[598396.620000] SQUASHFS error: xz_dec_run error, data probably corrupt
So all the clues point to data corruption. Question though, where? How do I determine if it is on my USB attached drive or on some internal storage in the R6400 itself?
# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock3 27.9M 27.9M 0 100% /
devtmpfs 124.3M 0 124.3M 0% /dev
devfs 124.3M 0 124.3M 0% /dev
/dev/mtdblock19 5.0M 396.0k 4.6M 8% /tmp/openvpn
/dev/mtdblock18 57.0M 2.9M 54.1M 5% /tmp/media/nand
/dev/sda2 5.5T 555.3G 4.9T 10% /tmp/mnt/usb0/part2
antinode
Feb 10, 2018Guru
> [edcf50]
I know nothing, but a quick Web search suggests that "Squashfs is a
compressed read-only file system for Linux.", which suggests that you're
looking at router firmware, not data on your external USB device(s).
https://en.wikipedia.org/wiki/SquashFS
> corrupt
"xz" sounds like (some form of) LZMA compression. A "mount" command
should tell you which file system is used on each mount point ("type
XXXX"). Might be informative.
- rickylFeb 13, 2018Tutor
