CaptainBetty
Apr 18, 2023Initiate
R6400 dies when an older Fire Tablet in in range or attempts to connect
Super weird issue with my R6400 (v2 I think). I use my router for my live sound company. Occasionally bands/musicians will connect to my Wi-Fi to adjust their monitors. It's been rock solid and p...
- Apr 18, 2023
I've had this issue before and sadly, I just switched routers versus trying to fix it.
Usually something within the device (tablet) causes a loop and causes issues.
Its tough to pinpoint because it forces the reboot and clears the logs.
You can always try disabling the logging features and see if that's whats causing it.
Or upgrade routers as that's a pretty base model gigabit router.
Apr 18, 2023Guru - Experienced User
- CaptainBettyApr 18, 2023Initiate
Thanks for the response. Greatly appreciate your input.
On one hand, I have no issues with this router 99.9% percent of time. It's just this one band I work with and this one guy's tablet that, for whatever reason, just kills my router.
On the other hand, yeah, it might be time to upgrade.
- plemansApr 18, 2023Guru - Experienced User
Try enabling the guest network and seeing if it causes issues on the guest network. It might work fine on there.
