tclpeterrabbit
Dec 12, 2022Tutor
R6400 Download performance drops when IPV6 enabled
I have a R6400 router (not v2) that has worked well. When I connect a Windows 10 PC directly to the cable modem I get close to my gigabit plan download speed. When I connect through the router using ...
michaelkenward
Dec 13, 2022Guru - Experienced User
What firmware version do you have on the R6400?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
tclpeterrabbit
Dec 13, 2022Tutor
The latest - V1.0.1.78_1.0.50
