AMZ57
Jan 24, 2024Follower
R6400 drops connection then can't remember its password to reconnect
I just started having an issue with my iPhone and iPad dropping off network then receive a password not valid error. I went to the automated helper and found there's been a firmware update. I then went to the nighthawk app followed instructions to update firmware, and receive a "firmware check error" I have been trying to fix this for 4 hours with no luck. Is there something I missed or is there another isssue?
Please advise Thank you
Anne Marie
Try this first:
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageAlso FYI:
A few things there, the automated helper is famously unreliable. I can miss updates for various reasons.
Try this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
