Rkedonnay
Oct 28, 2020Tutor
R6400 Factory Reset reset NEW IP address to all attached devices
R6400 (version V1.0.1.62_1.0.41) fter factory reset for connectivity issue, that issue was resolved. Now, I have discovered that all attached devices were assigned a new IP address. This is only a h...
antinode
Oct 28, 2020Guru
> [...] I have tried to add the IP address with a new port
> configuration and OP system will not accept. [...]
Huh?
> [...] Is there a way to reassign IP address? [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for topics like
"Manage Reserves [sic] LAN IP Addresses" and "Reserve an IP Address".
- RkedonnayOct 28, 2020Tutor
antinode wrote:> [...] I have tried to add the IP address with a new port
> configuration and OP system will not accept. [...]Huh?
"Manage Reserves [sic] LAN IP Addresses" and "Reserve an IP Address".antinode Thank you for your response. I have read and re-read the Owner's manuel for the R6400. The IP address is only addressed in the area for access control - block a device and allow a device on the network.
No, there is no reassign IP address on the router. There is a update IP address in the printer BUT it will not accept because it is not in the Wiindows 10 assigned local port and will not accept a recongiuration that I've been able to satisfy W10. HP is useless in their support in that it is now out of warrantly. Netgear would love to help me for hourly charges as my router is also out of warranty. Therefore, I've reached out to the Netgear community for the expertise that may be available.
I appreciate your time in responding. Thank you again.
- antinodeOct 28, 2020Guru
> [...] I have read and re-read the Owner's manuel for the R6400. The
> device and allow a device on the network.Read it again?
> [...] Look for topics like "Manage Reserves [sic] LAN IP Addresses"
> and "Reserve an IP Address".Did you? (Clearly, _I_ read the User Manual, because otherwise I
wouldn't misspell "Reserved" as "Reserves" here.) Try page 114?ADVANCED > Setup > LAN Setup : Address Reservation is where you
assign a specific address to a particular client device.After you define one or more address reservations, you might need to
shut down the router and your other devices, and then restart
everything, before those new reservations will be effective.
> [...] There is a update IP address in the printer BUT it will not
> not accept a recongiuration that I've been able to satisfy W10. [...]You lost me. With my weak psychic powers, I can't see what you did,
or what happened when you did it.
"will not accept" is not a useful problem description. It does not
say what you did. It does not say what happened when you did it. As
usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.- RkedonnayOct 28, 2020Tutor
antinode wrote:> [...] I have read and re-read the Owner's manuel for the R6400. The
descriptions or interpretations.antinode It is wonderful to know the definition of the terms in technical manuals. It was very kind and helpful for your enlightening me to translate the terminology.
I am sad to learn you missed my telepathy (injecting humor) with my explanation of Windows 10 not recognizing a new port reconfiguration. Perhaps it has little to nothing to do with correcting this problem.
I will read this again using your very helpful suggestions. I sincerely appreciate your time and effort to help with this printer issue.
If I have additional questions, I will let you know. Also, when the problem is solved, I will let you know.
Thank you again.
