Simarti28
Jul 01, 2016Aspirant
R6400 Failed Firmware Update-Corrupt
I have a R6400 AC1750 router. While attempting to update to the latest firmware version, the update failed. Now my routers internet light constantly flashes amber and the power light doesn't come on, ...
- Jul 09, 2016I contacted Netgear support to get a RMA # so I could get a warranty replacement. Before receiving my RMA #, the support agent had me troubleshoot several different ways in an attempt to communicate with the router. After about 1 hour on the phone I got the RMA and now have a warranty replacement in my possession. Just a FYI, the troubleshooting was free of charge and I only had to pay shipping cost for the replacement, $17 for advanced shipping method, this covers shipment to you and shipping of the defective unit back to them.
DexterJB
Jul 03, 2016NETGEAR Moderator
Hi Simarti28,
There is no need for you to unzip the .chk file since that will be the firmware itself. Just make sure you have downloaded the correct firmware version for the specific router model. You may refer to the link below for the steps on how to perform TFTP.
Dexter
Community Team
Simarti28
Jul 04, 2016Aspirant
DexterJB, I forgot to ask.....when I'm updating the router manually do I connect the Ethernet cord from my PC to a LAN port or the WAN port on the router? Also, does my PC need to be connected to the Internet at that time?
Thanks,
Simon
- VE6CGXJul 04, 2016Master
First of all what caused your router bricked? Did you get any error message? Was doing it on wireless connection? Or you did something stupid to the router B4 updating finished? In a situation like this, first thing you should do is to figure out what state router is in.Disconnect everything from router except one LAN connection to your PC, then see if you can access the router, if not run 'ipconfig'
command to see what gateway ip address is. ttfp needs precondition for the router, it does not work no matter what the router status is.
You trying to update again? Then your router is accessible?
- Simarti28Jul 04, 2016Aspirant
I was updating wirelessly, now I know that this is not recommended, but when I went to update it said "ensure that you are connected to your router wirelessly or via Ethernet cord" so I figured wireless would be fine. If it's not recommended to update through wireless then they should change that message when you go to update. I did receive an error message with a sad face icon on a piece of paper. I don't recall the exact message. Ipconfig does not return an IP address nor can I ping the router. I'm not home now but will try tfpt later tonight or tomorrow and reply back.
- TheEtherJul 04, 2016Guru
Simarti28 wrote:DexterJB, I forgot to ask.....when I'm updating the router manually do I connect the Ethernet cord from my PC to a LAN port or the WAN port on the router? Also, does my PC need to be connected to the Internet at that time?
Thanks,
Simon
You should disconnect the router from the everything except power. Then connect a PC to one of the router's LAN ports. If your PC fails to get an IP address, then the router is probably not booting up properly. In this case, you will have to recover the router by installing new firmware using TFTP.
You can follow Netgear's instructions for using TFTP (link). Follow the instructions carefully to statically assign an IP address on your PC. Don't forget to revert this after you recover the router.
Windows has a built-in TFTP client, so you don't necessarily have to download the ones suggested in the article. See here for details to enable it.
TheEther Thank you for your reply, I am not able to get an IP address nor can I ping the router. Ipconfig doesn't return a response. I'll check you links later tonight or tomorrow and reply back.
- VE6CGXJul 05, 2016Master
In your case being unable to ping the router not even once, we don't know the router CFE is presenting firmware load time windows. We can tell by looking at ttl time when ping is successful. So most unlikely tftp won't work. I just wonder some who says like tftp will save your router no matter what(like cure all magic, it is not) If CFE is buggered up it becomes VERY difficult to save the rouuter. Experienced, knowlegeable hands usually revive the router but can you do that? I hope your router is not in that deep hole.Again tftp can work only in certain conditions.
TheEther So I tried the firmware update again following the instructions exactly as stated. However, the power light never illuminates. The only light that is illuminated is the LAN 1 which is where my Ethernet cord is plugged in from my PC. I have tried this at least 8 times now and I receive the same message each time "Unable to get responses from server." I used the latest firmware file downloaded from Netgears website for my exact model. Enabled TFTP per your other link and have tried third party TFTP programs. I can not connect with this router in any way whatsoever. Thinking about getting a warranty replacement since I'm still within the 1-year period. VE6CGX DexterJB
- TheEtherJul 05, 2016Guru
It is critical to start the TFTP process at just the right time, which is shortly after applying power to the router. There is only a short period when the bootloader is active and ready to accept new firmware. This period is only a few seconds; once it expires the bootloader will proceed to load the firmware stored in the router.
A common tactic is to open a Command Prompt on the PC and enter ping -n 1000 192.168.1.1. Apply power to the router and wait for the pings to succeed. Then start the tftp transfer as soon as possible.
If this doesn't work, then the router may only be recoverable through the serial console. Unfortunately, this requires an inexpensive but special cable and, frequently, disassembly of the router to access the serial port. This is beyond the capabilities of most people. Since you are within the warranty period, replacement is the better option.
