abhi_shah
Oct 31, 2022Aspirant
R6400 firmware upgrade 1.0.1.78_1.0.50 from 1.0.0.62 issue
d update is saying successfully applied but it keep showing update available. and see d same versions: upgrade version:1.0.1.78_1.0.50; current version:1.0.0.62
- Oct 31, 2022
Try updating using a wired PC and web browser...
Oct 31, 2022Guru - Experienced User
How are you applying the FW update? Wired PC and web browser, MS EDGE or FireFox is recommended.
Be sure to clear out all browser caches before and after loading the FW file.
After the FW update is applied and the router is back to ready, a factory reset maybe needed and setup from scratch.
abhi_shah
nighthawk apple app. it worked earlier through mobile app, don't remember issue before.
- FURRYe38Oct 31, 2022Guru - Experienced User
- abhi_shahOct 31, 2022AspirantWorks from browser. Update complete. Thank you.
- FURRYe38Nov 01, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
