abhi_shah
Oct 31, 2022Aspirant
R6400 firmware upgrade 1.0.1.78_1.0.50 from 1.0.0.62 issue
d update is saying successfully applied but it keep showing update available. and see d same versions: upgrade version:1.0.1.78_1.0.50; current version:1.0.0.62
- Oct 31, 2022
Try updating using a wired PC and web browser...
abhi_shah
Works from browser. Update complete. Thank you.
Nov 01, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
