NotAnITgenius's avatar
Mar 24, 2019
R6400 FIRMWARE UPGRADE v1.0.1.46_1.0.32 = REDUCED WIfI COVERAGE AREA
Updated R6400 Router to recommended firmware V1.0.1.46_1.0.32 and immediately noticed a reduced WiFi coverage area for all peripherals that tried to connect. Is there a way to reverse the upgrade?
  • NotAnITgenius's avatar
    Mar 31, 2019
    Was able to get good WiFi coverage/signal back after upgrading firmware, but it required a HARD RESET of the router and I had to re-configure all my equipment to access it.  Happy that I got it fixed.  NOT Happy that it took a full day to get everything re-configured.  NETGEAR PLEASE FIX YOUR FIRMWARE UPDATE TO KEEP ALL SETTINGS IN PLACE WHEN AN UPGRADE IS COMPLETED, or at least warn the user of the specific settings that are not compatible with the update and may have to be re-configured after the update.
