Showalter's avatar
Showalter
R6400 Firmware V1.0.1.6_1.0.4 Trashed my router
Does a factory reset return it back to factory Firmware? Has anyone tried ?  Did the update yesterday, and now it keeps disconnecting (the router). Getting PO real quick, since all of our TV's are sm...
  • DexterJB's avatar
    Feb 07, 2016
    Hi @Showalter,
    Doing a factory reset will not set the router's firmware back to the previous version. Instead, it will reset the settings back to default. It is recommended that you perform a factory reset after a firmware update then reconfigure your settings. If the issue persists, you can manually flash/install the previous firmware version if you prefer. You may check the links below for the steps.
    http://kb.netgear.com/app/answers/detail/a_id/23960
    http://kb.netgear.com/app/answers/detail/a_id/9665
    Dexter
    Community Team
