dorlich
Feb 14, 2018Aspirant
R6400 Firmware Version 1.0.1.26 issues
hi all. just installed new firmware for this device . it broke my internet connection.. VPN connection drops every minute.. soft reset and hats reset is not solving the issue. anyone with the same...
DexterJB
Feb 18, 2018NETGEAR Moderator
Hi dorlich,
Have you tried re-flashing the latest firmware then do a factory reset? If not, that is something that you can try and check if the issue persists.
Dexter
Community Team
dorlich
Feb 25, 2018Aspirant
thanks Dexter.
even the workaround hasn't fix the stability issues it is working fine. I started seeing seeing issues since version .32
thanks
thanks
