Memeyerc
Mar 29, 2021Follower
R6400 FTLOG WONT UPDATE FIRMWARE
Someone help the vicious user name password cycle when trying to update firmware. If ive got nighthawk app i should be able to click a button and update? Sends me to another website to enter it all ag...
Mar 29, 2021Guru - Experienced User
You have the R6400? And you're trying to update it using the app?
I'd highly recommend against updating using the app. I'd recommend doing it over a hardwired connection to the router.
It shouldn't matter since the router is supposed to host the download/install process but when we see corrupt firmware issues, its usually when done over wireless or when done using the app.
what firmware version are you on?
What modem/gateway is it connected to?
