hypnoregression
Feb 03, 2017Follower
R6400 Genie will not go to the Basic Button for ports
OK first am I in the wrong place? My R6400 router not on the list In any event, I have a R6400 connected to cable This is wired to a Mac Mini late 2009 2.26 Ghz) running OS X 10.11.7 OSX Server...
- Feb 06, 2017
Hi hypnoregression,
The port forwarding/triggering option is under the Advanced tab (Advanced > Advanced Setup > Port Forwarding/ Port Triggering). You can also try using another browser. Also, we do not recommend updating the firmware if you are remotely located from the router.
Dexter
Community Team
DexterJB
Feb 06, 2017NETGEAR Moderator
Hi hypnoregression,
Dexter
Community Team
