hypnoregression's avatar
Feb 03, 2017
R6400 Genie will not go to the Basic Button for ports
OK first am I in the wrong place? My R6400 router not on the list   In any event, I have a R6400 connected to cable This is wired to a Mac Mini late 2009 2.26 Ghz) running OS X 10.11.7 OSX Server...
  • DexterJB's avatar
    Feb 06, 2017
    Hi hypnoregression,
    The port forwarding/triggering option is under the Advanced tab (Advanced > Advanced Setup > Port Forwarding/ Port Triggering). You can also try using another browser. Also, we do not recommend updating the firmware if you are remotely located from the router.
    Dexter
    Community Team
