lnbbrady
Oct 16, 2021Tutor
r6400 gets error message “trouble finding site”
Setup Home network on satellite connection through a modem Satellite service provided by Viasat thru CTESC Modem: Surfbeam 2 Satellite Modem, Model KM4100 Netgear AC1750 smart wi-fi router (...
Oct 16, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since this started?
Is there any security features on the router that are enabled like Armor or any parental controls?
lnbbrady
Oct 16, 2021Tutor
We did do a factory reset on both the modem and the router.
We do not use Armor or any other router security programs - just Avast for the computer itself. But even if we did, access control shouldn’t be the problem since it doesn’t block us every time.
We have no children at home, so no parental controls.
Firmware version V1.0.1.74_1.0.48 (listed under setup in my original post)
- FURRYe38Oct 16, 2021Guru - Experienced User
Is this a recent problem that just appeared or has this been a on going problem?
- lnbbradyOct 16, 2021Tutor
It is fairly recent. Don’t know exactly when it happened since things around here have been rather hectic – maybe a month or so ago?? We’ve had the router since 2016 with no problems until this showed up.
- lnbbradyOct 20, 2021Tutor
Hi, Mr. Guru - Did you give up on my problem? I'd like to go forward and solve this issue one way or the other. My gut tells me it is a software issue somehow. Either a setting is wrong or somethning else, but I can't for the life of me think of anything and need the help of someone who has more knowledge of routers than I do. If it is not you, please let me know so I can go elsewhere.
