Srminnehan
Apr 19, 2017Follower
R6400 in bridge mode
My R6400 is not communicating with the "little black box" of our internet provider... rise broadband. And the second light from the left is not lighting up. I first thought it was a problem with rise ...
- Apr 23, 2017
Hi Srminnehan,
1. Are you are referring to the Internet light (planet symbol)?
2. Please try using another Ethernet cable to connect the router to the modem.
3. Please make sure that both ends of the cable are properly connected.
4. You can also try doing a loop back test to check if the WAN port on the router is working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
DexterJB
Apr 23, 2017NETGEAR Moderator
Hi Srminnehan,
Dexter
Community Team
DexterJB
Apr 27, 2017NETGEAR Moderator
Hi Srminnehan,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
