rrsrer
Aug 17, 2017Follower
R6400 Lan Speed Gigabit
Hi All, Before I go ahead and get new cat5e cables and begin tinkering with my NIC cards, and perform hard resets of the router. Can someone tell me if my 4 lan ports on the R6400 support gig...
- Aug 17, 2017
> Can someone tell me if my 4 lan ports on the R6400 support gigabit
> speed?
The User Manual says so. Go to http://netgear.com/support , put in
your model number (plain "R6400" or "R6400v2"?), and look at
Documentation. (Then look at the documentation.)
> I have two devices connected and they are running at 100mb
What are these "two devices"? How did you determine that speed?
antinode
Aug 17, 2017Guru
> speed?
