unixdude
Aug 16, 2017Aspirant
R6400 Lost Configuration on Reboot Everytime
Everytime I reboot my router or if I lose power I lost my wifi network configuration where the gateway ip address, and the subnet I've assigned. When I assign 192.168.100.0 it always defaults ba...
- Aug 29, 2017
Hi unixdude,
The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24104
Dexter
Community Team
antinode
Aug 16, 2017Guru
> Under advanced tab
> wan setup
At least one of us is confused. On my R7000 (V1.0.7.6_1.1.99), the
only address under ADVANCED > Setup > WAN Setup is the "Default DMZ
Server". The router's WAN IP address is set under ADVANCED > Setup >
Internet Setup: Internet IP Address, and its LAN address (with netmask)
is set under ADVANCED > Setup > LAN Setup: LAN TCP/IP Setup.
Your R6400 could be different, but perhaps it would help if you
explained what you're trying to do.
unixdude
Aug 17, 2017Aspirant
I have another device on my network I have at 192.168.1.1 and I don't want my router to start using that address. I tell the software that the router is 192.168.100.10, and all new devices use 192.168.100.20+ (That way I'm using a different subnet than the other device). When it reboots it should maintain those settings but it reverts back to 192.168.1.1 and all the devices start connecting as 192.168.1.2, .3, .4 and etc.
- DexterJBAug 21, 2017NETGEAR Moderator
Hi unixdude,
1. What is the firmware version of the router?
2. Have you tried resetting the router to factory defaults?
3. Please make sure that the router is not set to AP mode.
Dexter
Community Team
- unixdudeAug 22, 2017Aspirant
Dexter,
The version is V1.0.1.24_1.0.18. I did see the AP node was on. I'll turn it off and see if that fixes the issue and reboot the router. That must be a default setting on the router with the AP mode on.
Also, when I rebooted the router it was a normal reboot not default settings. The other thing I noticed is a few times the router was rebooted somehow by loss of power or the os decided to reboot and it came back wth the default settings.
- DexterJBAug 23, 2017NETGEAR Moderator
Hi unixdude,
Thank you for the update. The device is set to router mode by default and not in AP mode. It is possible that it is setting itself up in AP mode during boot up since it is detecting that it is within the same IP range as the your other router. You can try configuring the device's IP first before connecting it to your other router.
DexterCommunity Team
