chipnewt
Jan 10, 2022Aspirant
R6400 Lost connection to internet. Windows 10 troubleshoot says problem is router.
I lost connection to internet. Firmware is very latest updated 3 days ago. computer system is windows 10. Windows 10 troubleshoot says problem is router but I still have wireless connection and one ...
Adan11
Jan 11, 2022Aspirant
Make sure Wi‑Fi is turned on. Select the "No internet connection" icon on the right side of the taskbar, and make sure Wi-Fi is turned on. If it isn't, select it to turn it on. Also, make sure Airplane mode is turned off.
Select Manage Wi-Fi connections (>) on the Wi-Fi quick setting, see if a Wi-Fi network you recognize and trust appears in the list of networks. If it does, select the Wi-Fi network, and they try to connect to it. If it says Connected underneath the network name, select Disconnect, wait a moment, and then select Connect again.
Try connecting to a network on a different frequency band. Many consumer Wi-Fi routers broadcast at two different network frequency bands: 2.4 GHz and 5 GHz. These will appear as separate networks in the list of available Wi-Fi networks. If your list of available Wi-Fi networks includes both a 2.4 GHz network and a 5 GHz network, try connecting to the other network. To learn more about the differences between 2.4 GHz networks and 5 GHz networks, check out Wi-Fi problems and your home layout myccpay
