BG4u
Jul 11, 2022Follower
r6400 lost guest password
I set up a guest password a couple of years ago and can remember what it is. Is there a way that I can reset it or find out what it was?
1 Reply
You can log into your router and view/change the ssid and guest ssid info.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
