MurrayWarnock
Oct 14, 2025Aspirant
R6400, Nethawk error checking firmware
Netgear AC1750, Model R6400; using Nighthawk app, Router Settings, Check For Updates, always receive an error. “Firmware Check Error There was a problem checking firmware update” How might ...
- Oct 15, 2025
Yea Netgear isn't going to provide anymore firmware updates to your router, either you use a third party firmware like dd-wrt that keeps it updated or just wait til your router dies and get a new one.
wcalifas
Oct 15, 2025Prodigy
Also, if you don't plan on keeping your router you can always put it on ebay and for sure someone will find a way to use it.
