hale93
Mar 30, 2016Aspirant
R6400 newby optimize wireless speeds any setting config needed?
Hi, newby here wanted to learn how can I really push the wireless speed. I have just bought the R6400, I have a qualcomm atheros ar956x wireless network adapter, and time warner 300MB speed. Wired I...
- Apr 02, 2016
Hi @hale93,
Devices (laptops) that have this adapter are specified to only connect to 802.11n which means that the adapter is not dual band. You may want to check for wireless interference using a WiFi analytics app/program.
Dexter
Community Team
DexterJB
Apr 02, 2016NETGEAR Moderator
Hi @hale93,
Dexter
Community Team
- hale93Apr 07, 2016Aspirant
Thanks for helping tried a program called inssider home and I am trying to find how to use it. I did not know about the adapter thank you so much, I need to find where to get a better connection in my house though, I will be looking in more about where the trouble is.
- DexterJBApr 10, 2016NETGEAR Moderator
Hi @hale93,
I'm glad to have helped out. You may also try using the WiFi analytics feature of the NETGEAR Genie app/program to help you identify the best channel, check for interference, and location to place the router and/or your device/s. You can download the latest version of the app/program using the link below on your preferred platform.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
