brboening
Aug 18, 2019Initiate
R6400 No internet
I activated a CM700 modem with spectrum today and have internet when directly connecting the modem to my laptop. I cannot get an internet connection from the router. My laptop will say it is connected...
- Aug 19, 2019Factory reset did the trick. I had tried that earlier but did not hold it long enough to truly reset. All good now!
michaelkenward
Aug 19, 2019Guru - Experienced User
Is this an R6400 that you had already?
Did you factory reset it?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- brboeningAug 19, 2019InitiateFactory reset did the trick. I had tried that earlier but did not hold it long enough to truly reset. All good now!
- michaelkenwardAug 19, 2019Guru - Experienced User
That's good news.
You are not the first person to have had problems getting a router to reset.
