ngandhi86's avatar
Jul 26, 2022
R6400: no wifi connection
Recently started losing Wi-Fi connection on the router, both 2.4 and 5. Only way to get the connectivity back is to reboot the router then it's good few days and it shuts off again. Performed factory reset multiple times but issue still exists/.
Firmware Version
V1.0.4.122_10.0.95
  • plemans's avatar
    Have you tried reinstalling the firmware or downgrading a version or 2?
  • michaelkenward's avatar
    michaelkenward
    It might help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
