Xyrien02's avatar
Xyrien02
R6400 not reaching gigabit on LAN
I'm currently subscribed to Xfinity's gigabit plan. I can't seem to get gigabit speeds when connected to the router by LAN. I'm getting gigabit speeds when connected directly to the modem but there...
  • michaelkenward's avatar
    michaelkenward
    Aug 25, 2018
    Looks like your modem is also a router. That can cause problems when connected to a second router.
    Might be worth investigating how you can set it to modem only (bridge) mode, or you could try putting the Netgear router into wireless access point mode. That would let you see if the speed goes up.
    There is a manual for the R6400 somewhere at the end of this link:
    >>> R6400 | Product | Support | NETGEAR <<<
    Check the section Use the Router as a Wireless Access Point.
