Xyrien02
Aug 24, 2018Aspirant
R6400 not reaching gigabit on LAN
I'm currently subscribed to Xfinity's gigabit plan. I can't seem to get gigabit speeds when connected to the router by LAN.
I'm getting gigabit speeds when connected directly to the modem but there...
- Aug 25, 2018
Looks like your modem is also a router. That can cause problems when connected to a second router.
Might be worth investigating how you can set it to modem only (bridge) mode, or you could try putting the Netgear router into wireless access point mode. That would let you see if the speed goes up.
There is a manual for the R6400 somewhere at the end of this link:
>>> R6400 | Product | Support | NETGEAR <<<
Check the section Use the Router as a Wireless Access Point.
Xyrien02
Aug 25, 2018Aspirant
Thanks for the reply.
Modem is Arris TG3482G.
Router firmware version is V1.0.1.42_1.0.28
michaelkenward
Aug 25, 2018Guru - Experienced User
- Xyrien02Aug 25, 2018Aspirant
Thank you so much!!
After putting my modem to bridge mode and changing my R6400 to wireless AP mode, I'm getting the same speeds as when I was connected to the xfinity modem directly.
You just made my day!
- michaelkenwardAug 26, 2018Guru - Experienced User
One of those changes is usually enough.
Modem to bridge more OR router to access point mode.
