josephk1
Sep 14, 2024Aspirant
R6400 or R6400v2
Does Netgear support monitor these forums? Hope so. I might have an issue that some folks have discussed on these forums; it seems my firmware is not at the correct level (current firmware on router ...
josephk1
Sep 15, 2024Aspirant
Thanks! Label on my router says "Model: R6400" so it is not a v2. Appears somehow I have the v2 firmware installed. I will proceed to install the R6400 firmware 1.0.1.78. Thanks.
michaelkenward
Sep 15, 2024Guru - Experienced User
Why am I not surprised?
Maybe the graphical user interface (GUI) is more accurate.
If you really do have the V2 model, then you should install
R6400v2 Firmware Version 1.0.4.128 - NETGEAR Support
The router should object if you try to install the wrong firmware for your version.
Just another user with time on their hands.
- sktn77aNov 15, 2024Virtuoso
Netgear is usually pretty good at not allowing the wrong firmware to be installed (ie a v2 image on a v1 router) and the model number on the back/bottom should have v2 if it's a v2. Not sure you got where you are but you can try downloading the current (latest) version of firmware for your router and install it manually.
Current version for the v1 is 1.0.1.78
Current version for the v2 is 1.0.5.128
