andrew1981
Jul 12, 2016Aspirant
R6400 Port Forward issues V1.0.1.12_1.0.11
I just purchased a new NETGEAR R6400 router. I am trying to set up some port forwarding rules that have worked perfectly on other NETGEAR routers. For example, inbound traffic on port 13389 should ...
- Jul 12, 2016
The Release Notes for V1.0.1.12_1.0.11 indicate that they enhanced port forwarding:
- Improves port forwarding by allowing fixed and range ports to be added to one rule.
If you upgraded from a previous version, then you may want to perform a factory reset to wipe out any incompatible configuration settings left over from the previous version. Then re-enter the port forwarding settings by hand. Do not restore from a backup configuration file because it, too, can be incompatible with the new version.
If this doesn't work, then try downgrading to an older version. You can find firmware here (link). Be sure to perform another factory reset after installation.
TheEther
Jul 12, 2016Guru
andrew1981
Jul 15, 2016Aspirant
Perfect! Backing up to v1.0.1.6_1.0.4 worked! The interface is not as clean, but whacha gonna do?
I did try a factory reset on the latest firmware, which did not work.
