jeffwest63
Jul 11, 2019Aspirant
R6400 port forwarding not available
I have a r6400 router and I am trying to turn on the port forwarding and it is unavailable? must be in the settings but I am unsure on where to look thank you in advance Jeff
- Jul 11, 2019
Worth a note: If your R6400 (or any other Netgear router) is operating in Access Point mode - not as a router - there can't be any port forwarding available.
jeffwest63
Jul 12, 2019Aspirant
Trying to open a port for our security system so I can remote view the cameras from mobile devices.
Im in NetGear Genie but the "port forwarding" is greyed out and not available in the ADVANCE settings
Im sure it is something simple but would appreciate any help! tyia
michaelkenward wrote:
jeffwest63 wrote:I have a r6400 router and I am trying to turn on the port forwarding and it is unavailable?
Why?
Tell people what you really want to do and you might get better advice.
michaelkenward
Jul 12, 2019Guru - Experienced User
jeffwest63 wrote:
Im in NetGear Genie....
Which one? Desktop? Mobile?
Most stuff is best done with the browser graphical user interface.
Not a cloud based system then. That's why Arlo is so much easier to use, albeit at a price.
As schumaku says, I assume that the R6400 is not in AP mode.
