ANSEL2
May 01, 2022Follower
R6400 port forwarding stopped
Had a static IP set up for device and set up port forwarding to 44158. Was working fine for weeks then all the sudden no longer opening that port, and port checkers reporting 44158 is closed. I rest...
tekzer0
May 01, 2022Aspirant
Every nighthawk or netgear router for that matter that i get has a terrible GUI and mine even after a factory reset wont even show my port forwarding options and if it does, like many other things it doesnt show, it disappears yet the option is usually still active. currently i cant see my forwarded ports even after a reset and then importing my previous settings that were saved. yet when i try to add the port forward even after a factory reset, it says that ports already forwarded. i wish i could actually perform a true factory reset... even reflashed the firmware.... wish someone would make new firmware for these garbage routers.... the rax75 was the worst $500 i ever bought new since the last nighthawk i bought new...def not getting the new 1000 dollar piece of garbage!
