ANSEL2
May 01, 2022Follower
R6400 port forwarding stopped
Had a static IP set up for device and set up port forwarding to 44158. Was working fine for weeks then all the sudden no longer opening that port, and port checkers reporting 44158 is closed. I rest...
michaelkenward
May 02, 2022Guru - Experienced User
ANSEL2 wrote:
Any idea why the rule is being ignored all of the sudden?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
