Collinson
Sep 16, 2023Aspirant
R6400 Readshare Vault
I can't seem to get Readyshare Vault set up for my R6400. Ready Share SW doesn't want to download, Netgear Genie doesn't recognize the USB Drive and my WIN 10 PC doesn't see it either. Where do I s...
michaelkenward
Sep 16, 2023Guru - Experienced User
How to setup ReadySHARE Vault (Free Backup Software)? - NETGEAR Support
Support for Readyshare Vault ends April 15, 2021 - NETGEAR Support
Gone the same way as ReadyCLOUD,
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
Collinson
Sep 24, 2023Aspirant
Thanks for the reply michaelkenward, but I've seen all those pages already and nothing on them seems to work. Network discovery file sharing is on and Explorer doesn't recognize \\readyshare. One of the pages mentions that Readyshare USB still works, but following that thread leads to a dead end. Guess there' no help.
- michaelkenwardSep 24, 2023Guru - Experienced User
What are you trying to achieve?
Your first message was all about ReadySHARE Vault and its software. Now you are talking about accessing \\readyshare
These are different issues.
For ReadySHARE you should check this:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
There are other things, but first you need to explain what you are really trying to achieve.
