pau11y
Mar 17, 2018Aspirant
R6400 readyshare stopped working
We've been using a seagate ext hdd for over a year (maybe two years?) via the back usb port as a readyshare drive. Had worked without troubles on wife's work computer (work's from home, win10) from d...
- Mar 20, 2018
Hi pau11y,
1. Please make sure that you have done a factory reset after the firmware update.
2. Does the issue persist when using a different storage device (another HDD, flash drive)?
3. Does the issue persist when using the other USB port?
4. Does the USB LED still light up if the issue occurs?
5. Does the issue persist on your other devices?
Dex
djhurlburt
Jun 26, 2018Apprentice
Thank you for your reply shumaku. Let's see:
1. "if you insiste having SMB 1.0 disabled on your Window system...."
I do not insist on this.
2. "Assuming your USB storage device is recognised..."
I can see the USB device in the netgear web-app (and in the Netgear Genie); however I cannot see the USB device through a web browser nor windows explorer.
3. I cannot see \\readyshare when I use windows-explorer
Do you think there is a BIOS issue where I should check to see if I need the latest BIOS for my system? It's just odd that this stopped working (seemingly) randomly.
schumaku
Jun 27, 2018Guru
Several explenation for these points in this thread already.
What happens if using the IP address, type in \\192.168.1.1 in Windows Explorer?
- djhurlburtJun 28, 2018Apprentice
Okay, so I went into "add / remove programs" and I made sure the SMB 1.0 client is turned on:
I had to reboot and after I did, I pulled up Windows Explorer and typed "\\readyshare" but it did not see this device.
Logging into the router through routerlogin.net, here is what I see:
If I click on "edit' I see this view:
clicking "edit" I get this window:
If I hit "apply" it says "share name cannot be NULL" so I typed in "backupDrive"
and then I see this:
but I still cannot see \\readyshare\... anything from Windows Explorer.
- schumakuJun 28, 2018Guru
Again, as I said before: NetBIOS discovery and name resolution is packed with the CIFS/SMB 1.0 Server feature (what makes some sense, think about it!) since Win 10 18xx.
Instead of \\readshare you can use ie. \\192.168.1.1 (the router LAN IP).
- djhurlburtJul 02, 2018Apprentice
if I type in "\\192.168.1.1" I get:
Your file was not found
It may have been moved or deleted.
ERR_FILE_NOT_FOUND - michaelkenwardJul 02, 2018Guru
ERR_FILE_NOT_FOUNDIs that before or after you get asked for the password?
- djhurlburtJul 02, 2018ApprenticeIt never prompted me for one.
It should ask you for the login details for your router. It does here.
