megden
Mar 30, 2017Follower
R6400 Router 2.4ghz not working, but 5ghz is fine
Purchased Router and installed Dec 2016. Has worked fine until 3 weeks ago when 2.4ghz kept dropping internet. I have reset the router, rebooted, restored to factory default settings, tested my mod...
- May 17, 2017
Hi kywest,
You can try re-flashing the firmware of the router then do factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
DexterJB
May 17, 2017NETGEAR Moderator
Hi kywest,
Dexter
Community Team
DexterJB
May 22, 2017NETGEAR Moderator
Hi kywest,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- kywestMay 26, 2017Aspirant
Thanks. I hadnt had a chance to follow the steps and it resovled on its own. I will keep this information for the future should it happen again.
Really apprecaiate your help.
