PowellRS
Oct 25, 2016Follower
R6400 Router 5G AP not working
My 5G AP has stopped. I have reset by removing power and paperclip in back. SSID is enabled, (I have turned this on and off with no effect) Region shows North America, Channel is 149 (I have chan...
- Dec 04, 2016
I managed to figure it out after a while. For some reason, the 5G was simply turned off, and I couldn’t find a way to turn it on via ythe NetgearGenie that was downloaded to my PC from the time I purchased the router. However, when I signed into the web-based Netgear Genie, I found the control to turn 5G radio on and did so. Then I reconnected my Roku and phone to 5G from the 2.4G.
Thanks for the advice.
Lee
Retired_Member
Oct 25, 2016try this
read the manual regarding 2nd button from the right top front, this may been pushed by accident, it should effect both bands which is strange that only 5g is off
or Push reset Until Power LED flashes, use default settings on router label...still bad replace it.
leesiegel
Nov 30, 2016Aspirant
When I first got my router, both 5G and 2.4G lights were on. Then 5G stopped working (the light is out and I can see Netgear70-5G on my phone, just Netgear70 (which is the 2.4G).
I have powered the router on and off. I have reset as recommended above. And I also tried turning the wireless light on and off. Still no 5G.
Please help. I have a lousy cell connection at home and depend on 5G wifi calling. My call quality went to hell when the phone (Android Samsung Galaxy S7) started using 2.4G
- DexterJBDec 01, 2016NETGEAR Moderator
Hi leesiegel,
1. Have you tried changing the wireless channel of the 5GHz band?
2. You can try re-flashing the latest firmware then reset and reconfigure the router. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- DexterJBDec 04, 2016NETGEAR Moderator
Hi leesiegel,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- leesiegelDec 04, 2016Aspirant
Lee
Good to know you got it working.
