PowellRS
Oct 25, 2016Follower
R6400 Router 5G AP not working
My 5G AP has stopped. I have reset by removing power and paperclip in back. SSID is enabled, (I have turned this on and off with no effect) Region shows North America, Channel is 149 (I have chan...
- Dec 04, 2016
I managed to figure it out after a while. For some reason, the 5G was simply turned off, and I couldn’t find a way to turn it on via ythe NetgearGenie that was downloaded to my PC from the time I purchased the router. However, when I signed into the web-based Netgear Genie, I found the control to turn 5G radio on and did so. Then I reconnected my Roku and phone to 5G from the 2.4G.
Thanks for the advice.
Lee
DexterJB
Dec 04, 2016NETGEAR Moderator
Hi leesiegel,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
leesiegel
Dec 04, 2016Aspirant
Lee
- DexterJBDec 04, 2016NETGEAR Moderator
Good to know you got it working.
