rajik84
Oct 10, 2016Aspirant
R6400 Router Intermittent Internet Issues
Hi All, Got Netgear R6400 and using behind the ISP provided Modem/Router although i have switched off the Wifi Functionality from the ISP Provided router. While normally connected sometime i am n...
- Retired_MemberOct 10, 2016
The ISP modem /router should be placed in bridge mode OR change the r6400 to AP Mode
Page 128
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Retired_Member
Oct 10, 2016The ISP modem /router should be placed in bridge mode OR change the r6400 to AP Mode
Page 128
rajik84
Hi, Thanks for reply.
I have connected with Netgear R6400 one NAS (QNAP) will it have effect if i change it to AP only mode?
@searay wrote:The ISP modem /router should be placed in bridge mode OR change the r6400 to AP Mode
Page 128
If set to DHCP it should be fine.....It will require a reboot......If using any remote access app or Qcloud you'll need check all those apps.
I use a QNAP TS470 Pro 16TB
- rajik84Oct 11, 2016Aspirant
@searay wrote:If set to DHCP it should be fine.....It will require a reboot......If using any remote access app or Qcloud you'll need check all those apps.
Hi,
I have changed it to wireless AP Mode, while one thing i have observed is now the copying speed to NAS is bit unstable as shuffle b/w 19Mb/s to 38 Mb/s before it was like 35-38Mb/s stable for few GB transfer of files. For Internet i need to test it bit more.
