Pistolpete143
Apr 02, 2017Aspirant
R6400 Router Intermittent Internet Issues
My internet provider says there are no issues on their side. Netgear tells me there are no issues on their side. If I use the ethernet cable straight to the laptop, with no router, I can connect to the internet. If I try using the router and go wireless, all gadgets say connected to my wireless but no internet...what is wrong with my router? All lights are correctly lit.
Hi Pistolpete143,
1. Is the router getting the correct WAN IP?
2. You can try MAC spoofing. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Pistolpete143,
Dexter
Community Team
- Pistolpete143AspirantUpdated firmware and it started working properly. This happens alot with this router so I will keep this link handy. Thank you for your help.
